john deere with a onan engine
   / john deere with a onan engine #1
edmoor
killbuck
john deere 318
i posted a thread about my 318 lawn and garden tractor with starter / flywheel issues....i have had no responses back on this. it took me 3 hours to register here....so i could try to find some help. im about to say **** with the internet and just go buy a kubota. i bought this to restore.....its all painted in showroom condition....new decals....now the **** starter is giving me fits. i have a new starter and a new flywheel in it. started it 3 times....starter sounds like ****.....and its burring up the the teeth on the new flywheel. im at lost here??????? any help?????
   / john deere with a onan engine #2
Having one of those myself I know how you feel. Mine has not run in a few years now. It takes so much time to get everything apart and is so frustrating when it doesn't work right. I have bee toying with the thought of repowering mine it is a nice machine when working well.
   / john deere with a onan engine #3
i got the problem solved. i made a bracket to support the starter....the onan has a weak 2 bolt method to hold it in place.....the 2 bolts are not enough to hold it secure. i run it today 10 or 15 times.....starter works fine now. now i need to remove the fuel pump.....it wont idle or run as high speed without half choke on. i went through the carb. and cleaned it....so its gotta be the pump now. i made a bracket to go thru the frame to to brace the starter with a large brass washer....to keep it from shifting. onan had a bad design on this starter mounting. 2 bolts are not enough to keep this starter from pivoting. thus all the issues with onan stater flywheel problems. i been a machinist all my life..there is always a way to improve a flaw.
   / john deere with a onan engine #5
Just curious... what model of 25-35 year old garden tractor of Kubota's where you thinking about. Sounds like the Dupont overhaul the 318 got did not fix everything?
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2019 FREIGHTLINER...
2017 PETERBILT 579 (A53843)
2017 PETERBILT 579...
2014 Dodge Charger Sedan (A51694)
2014 Dodge Charger...
2018 INTERNATIONAL LT625 (A53843)
2018 INTERNATIONAL...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51691)
2001 Dodge Ram...
2005 FL70 Freightliner, CAT C 7 Engine (A52384)
2005 FL70...
