John Deere Water Pump
/ John Deere Water Pump #1
Scruffy1
Darrington, WA
Kubota B2620
Can anyone tell me the torque required for the bolts on the water pump? The tractor is a John Deere LX178 garden tractor, engine number FD440V004089. The bolts are (JD part number) M6 X 45 (19M7834), M8 X 12(19M7864), M6 X 80 (19M8145) Thank you for any help provided. Scruffy
/ John Deere Water Pump #2
I can give you CAT's torque specs for these bolts. M6 diameter nuts/bolts are 105 +/- 27 lb in. M8 diameter nuts/bolts are 250 +/- 62 lb in. These would be for grade 8 bolts/nuts (class 10.9). Hope this helps a little. EDIT: I just noticed for a 8.8 class of bolt the M6 only 44 lb in and the M8 is only 195 lb in.
CATERPILLAR 299D2 SKID STEER (A62129)
CATERPILLAR 299D2...
KUBOTA K7796-24" PIN ON EXCAVATOR BKT (A62130)
KUBOTA K7796-24"...
UNUSED JCT 84" HYD GRAPPLE BUCKET (A62131)
UNUSED JCT 84" HYD...
APPROX. (30) 2"X6"X6' CHANNEL IRON (A62130)
APPROX. (30)...
CAT 953 Crawler Loader (A61166)
CAT 953 Crawler...
2025 80in. Hydraulic Dual Cylinder Grapple Bucket Skid Steer Attachment (A61567)
2025 80in...
