John deere van brunt model b drill
   / John deere van brunt model b drill #1
Tony Harford
John deere
Looking for an 18 tooth gear and a hub cap that is held on by 3 screws.
   / John deere van brunt model b drill #2
Are the part numbers stamped, or cast into the pieces, or have a parts manual with the part numbers..?? If so, do a search on Google with those part numbers.
If no luck doing that, place a "want to buy" ad at TractorHouse. Third item down in the column at top left of page. https://www.tractorhouse.com/
I've found using the OEM part number is the best way to find parts of any kind.
   / John deere van brunt model b drill #3
Welcome to TBN
Believe it or not back 55 or so yrs ago I unloaded NEW JD model B drill components from a railroad box car & then got the "pleasure" of assembling the pieces into grain drills. I can't remember ever seeing in person a model B drill with wheels with bolt on cap. IIRC some sprockets have part # cast into sprockets
18 tooth sprocket I located is part number M10113 which is listed on JD's parts site @ $115. Hub cap is PN N160060 but not listed on JD Parts or Parts Depot search
UNUSED LANDHONOR MPF-11-2000G PALLET FORKS FRAME (A54757)
UNUSED LANDHONOR...
2020 ANTHEM 64T DAY CAB (A54607)
2020 ANTHEM 64T...
2008 FORD F350 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F350 XL...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
Pair 2 - ST225/75R15 radial trailer (A53421)
Pair 2 -...
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A54757)
UNUSED WOLVERINE...
