John Deere Transmission Fluid change
   / John Deere Transmission Fluid change #1
bubbacuse77
Platinum Member
Wisconsin
John Deere 3520, John Deere X749
Anybody do a transmission/hydraulic fluid change on their 3000 series tractors, specifically a 3520. JD dealer is asking $75 for a transmission sump filter. Also anybody use other less expensive hydraulic fluid besides the brand name JD stuff and have you had adverse affects.
   / John Deere Transmission Fluid change #2
Deere's list on this filter is almost $100, sounds like you are getting a little bit of a deal here. Unfortunately hyd/transmission filters are the most expensive filters for any of these applications (regardless of tractor color). Am assuming you are beyond the warranty point or would not be considering a brand change of oil, if still under warranty tread carefully would be unfortunate to not have a drastic failure pd for just to save a few bucks on oil.
   / John Deere Transmission Fluid change #3
I quit running JD oil after I read about using other make equivalents....(the hours drive one way to the dealer helped as well) Tractor now has 4500hrs on it. I have a local source for filters as well but I don't recall the price.
Guys, thanks for the inputs
   / John Deere Transmission Fluid change #5
I even use JD Hy-Gard in my Kubota and MFs.
   / John Deere Transmission Fluid change #6
I will add to the comments.
You have an expensive piece of equipment so why go cheap on lubricant and filters.
I always use the John Deere oils and filters.
Have to do a hydraulic oil change with 2 pails of oil at $136 each in Canada. Ouch
2024 Dig Master DM100 Mini Excavator, NEW! (A52384)
2024 Dig Master...
John Deere 700 Hydraulic Hay Rake - Durable Side Delivery Rake for Efficient Windrowing (A53472)
John Deere 700...
2025 INDUSTRIAS AMERICA 227T 7' X 22' HYD TILT TRL (A51247)
2025 INDUSTRIAS...
UNUSED HURRICANE STAND ON SKID STEER (A51247)
UNUSED HURRICANE...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A52377)
2018 JLG 1644 4x4...
