John Deere Transmission Fluid change
   / John Deere Transmission Fluid change #1
bubbacuse77
Platinum Member
Wisconsin
John Deere 3520, John Deere X749
Anybody do a transmission/hydraulic fluid change on their 3000 series tractors, specifically a 3520. JD dealer is asking $75 for a transmission sump filter. Also anybody use other less expensive hydraulic fluid besides the brand name JD stuff and have you had adverse affects.
   / John Deere Transmission Fluid change #2
Deere's list on this filter is almost $100, sounds like you are getting a little bit of a deal here. Unfortunately hyd/transmission filters are the most expensive filters for any of these applications (regardless of tractor color). Am assuming you are beyond the warranty point or would not be considering a brand change of oil, if still under warranty tread carefully would be unfortunate to not have a drastic failure pd for just to save a few bucks on oil.
   / John Deere Transmission Fluid change #3
I quit running JD oil after I read about using other make equivalents....(the hours drive one way to the dealer helped as well) Tractor now has 4500hrs on it. I have a local source for filters as well but I don't recall the price.
Guys, thanks for the inputs
   / John Deere Transmission Fluid change #5
I even use JD Hy-Gard in my Kubota and MFs.
   / John Deere Transmission Fluid change #6
I will add to the comments.
You have an expensive piece of equipment so why go cheap on lubricant and filters.
I always use the John Deere oils and filters.
Have to do a hydraulic oil change with 2 pails of oil at $136 each in Canada. Ouch
18-1 gallon jugs pure Anti-freeze (A53117)
18-1 gallon jugs...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
WORKSAVER RMB-325-PW LOT NUMBER 104 (A53084)
WORKSAVER...
MANITOWOC QD08902A ICE MAKER (A51248)
MANITOWOC QD08902A...
UNUSED FUTURE SF60 HYD MAST W/ 60" FORKS (A51248)
UNUSED FUTURE SF60...
UNUSED JCT 72" HD BRUSH CUTTER (A51248)
UNUSED JCT 72" HD...
