John Deere Trans Oil
   / John Deere Trans Oil #1
narampa
Bronze Member
canada
445 johndeere
Anybody have any Idea where I can find a compatibility chart for oils for John Deere.
John Deere Hy Gard is what I have been using as I know the wrong oil in the transmission can be a real bad thing.
The temp range I operate in -40 to 100 deg.
Not looking for opinions just facts.
   / John Deere Trans Oil #2
I have looked and never found a solid list that I would trust my investment to.
You don't lose much fluid in the way of day to day operations. Just if there is a leak, which you need to fix first.
IMHO, If you are replacing the fluid won't you already be at the dealer getting new filters? That is what I found and buying 30L of Hy-gard is around $100 a small investment for a $40000 tractor.
I agree with you however the tractor is in a remote area and the nearest John Deere dealership is miles away. We have a good store of filters but oil is a problem for the distance as everything is flown in by small aircraft. John Deere dealerships are are 300 miles. But the fuel dealers are closer and we would like to have oil that is compatible.
I know what you mean by trusting a list.
But I thought I would ask.
   / John Deere Trans Oil #4
I will tell you what I tell all the Kubota owners, John Deere doesn't make hydraulic oil. Someone makes it for them and puts on a sticker. It is the same oil that others sell if it meets the John Deere specifications. Lots of oil meets JD, Kubota, NH, Case and many others in the same can. The specs are written right on the cans as to which specs the universal oil meet or exceed.
Just check the labels to see if they list the equivalents to the universal hydraulic oil.
   / John Deere Trans Oil #5
Even though it's a hassle, I do recommend using the Deere brand oil. Hydraulic fluid isn't changed that often and that extra bit of hassle may be be very worthwhile.
I don't have a lot of choice at the moment as the oils that are available are missing one spec that that John Deere requires. So for the time being I am going to sit tight.
Fuel supplier is going to see what he can do.
I know exactly where your coming from I worked 30 years for an oil company.
   / John Deere Trans Oil #8
PRODUCT
Product Name: JOHN DEERE LO HYGARD TRANSMISSION & HYDRAULIC FLUID
Product Description: Base Oil and Additives
MSDS Number: 12940
Intended Use: Hydraulic/transmission fluid
COMPANY IDENTIFICATION
Supplier: Imperial Oil Products Division
240 4th Avenue
Calgary, ALBERTA. T2P 3M9 Canada
   / John Deere Trans Oil #9
A number of years ago John Deere used to source at least some of their HyGard oil from Mobil with Mobilfluid 423.
I used to work for Mobil in Industrial Lube sales.
   / John Deere Trans Oil #10
Low bid, always low bids get the contract.
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2017 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2017 CATERPILLAR...
2014 VOLVO VNM DAY CAB (A51222)
2014 VOLVO VNM DAY...
WATER CONTAINMENT/TRASH CONTAINMENT SKID (A50854)
WATER...
2013 Ford F-150 Ext. Cab Pickup Truck (A50323)
2013 Ford F-150...
2007 Jeep Liberty (A50515)
2007 Jeep Liberty...
