john deere tractor mud exam
/ john deere tractor mud exam
: Mavi2:: Dance1:: Mavi2:
/ john deere tractor mud exam #3
Another classic example of stubbornness will overcome common sense
Must have frost in the ground since it didn't sink or dig any deeper
/ john deere tractor mud exam #4
Reminds me of the Lady I saw driving some low slung Audi in a Snow Storm.
That was a TOTAL fail, leaving his implemant behind.
/ john deere tractor mud exam #5
Been there, done that. Total fail is having to leave implement and tractor there and walk out to get home. Or worst total fail is damaging equipment and then having to walk out.
If you work fields in any crop that you have tight windows to get baling of hay or spraying or planting done sooner or later you are fighting the elements.
/ john deere tractor mud exam #6
If the whole purpose of the excercise was to pull your load somewhere and it stayed stuck in the field, I would have to say it was a TOTAL fail.
Just like this. Disconnected trailer and went back to base, Took an excavator to pull out the trailer. Not even worth a participation ribbon!
/ john deere tractor mud exam #7
I know that crops have to be harvested, fields have to be prepared and there are time constraints to everything. But going out in the field and having this happen accomplishes nothing. Is THIS THE WAY that most will use to check for acceptable operating conditions???
/ john deere tractor mud exam #8
I'm sure everything was fine and good to go when he started:
- with an empty light wagon.
- in the part of the field that wasn't as soft.
Typically it's not a static, uniform situation. It's more "Well, stay away from that spot, or only go here but not there if you're loaded heavy." Sometimes the only way one finds the "edge", is by going over it.
/ john deere tractor mud exam #9
And it is sometimes amazing where you find these soft spots. Could be half way up a hill, top of the hill, highest spot in the field. As Forest Gump says "it happens"
/ john deere tractor mud exam #10
Somewhat like the sage advice handed out regards tornado safety guidelines.
"Go to a safe place".. Duh! that be unknown place for sure, until after the tornado passes by.
Same with soft spots.. most of them can drive right on through, but there are the 5% that it won't happen that way..
/ john deere tractor mud exam #11
Now he got another job to do after ground dry's. :rolleyes:
New/Unused Wolverine 84in Quick Attach Snow Pusher (A61166)
New/Unused...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A61165)
IMPORTANT PLEASE...
(APPROX. 100) UNUSED SDLANCH 6' CORRUGATED STEEL (A62131)
(APPROX. 100)...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
2021 Ford F550 4X4 Service Crane Truck (A62613)
2021 Ford F550 4X4...
New/Unused Electric Golf Cart (A61166)
New/Unused...
