john deere tractor 6415 idles funny
   / john deere tractor 6415 idles funny #1
joe72
midway tennessee
john deere 6415 4wd
i have a john deere 6415 4wd the engine will rev up and back down all by its self. It will run fine for awhile then it will do this 3 or 4 times in a row then run fine again for awhile.
   / john deere tractor 6415 idles funny #2
Is it doing this when you actually have it throttled up? In other words, is it actually just losing RPM and then gaining it back? If so, then you likely have a fuel starvation issue like I recently had with my 6405. Read that recent thread of this month and you'll learn a lot. If it is gaining RPM's when you have it throttled down, then that's a whole other issue. Could be the linkage, governor, etc. But first thing first. If its fuel flow, you'll learn from previous thread about possible solutions. Mine ended up being a blocked screen at the bottom of the fuel pick up line in the tank. Easy fix. Good luck.
It will do this while it is sitting running all by itself and it will do it when you are useing it in the field. We have changed fuel lines filters cleaned the screen at the bottom of the fuel pick up line in the tank. Also changed the hand throttle sensor. We tried it with the foot throttle sensor unhooked yesterday while baleing hay and it still acted up. We also cleaned the fuel tank cap made sure the cap wasnt stopped up.
Informational Lot - Shipping (A53473)
Informational Lot...
2005 Butler Pole Trailer, 25000 GVWR (A52384)
2005 Butler Pole...
2004 Land Rover Range Rover HSE SUV (A51694)
2004 Land Rover...
2013 Freightliner Hydro Vac Truck (A53117)
2013 Freightliner...
2016 FREIGHTLINER CASCADIA SLEEPER (A53426)
2016 FREIGHTLINER...
2011 New Holland B95B Cab MFWD Loader Backhoe (A53473)
2011 New Holland...
