JOHN DEERE STX46 Mower Deck Droop
   / JOHN DEERE STX46 Mower Deck Droop #1
jlgurr
Veteran Member
Bostic, NC
Massey Ferguson GC1705, John Deere STX46
Having a problem with a sagging mower deck. (I know, it could be worse right? LOL) This lawnmower was new in 1998 but has been very well taken care of. The problem is the front of the mower deck does not raise as high as the rear when you lift it. Tried tightening the two rods at the front which connect under the front axle but have run out of thread. Not sure why this is happening. Could there be something else worn that I am not seeing? This does not cause a HUGE problem but it can be aggravating when you need more ground clearance when doing yard work.
Thanks,
Jeff
2016 Ford SD Dump Truck (A52377)
2016 Ford SD Dump...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
Adams 6Ton Hydraulic Lime Spreader (A55301)
Adams 6Ton...
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A52472)
2013 3400QB...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A55301)
Kuhns AE10 Small...
