Mowing John Deere STX 46 drive belt
   / John Deere STX 46 drive belt #1
jmbeaver
Point Pleasant, WV
John Deere
Is there any way to adjust/tighten the drive belt on a John Deere STX 46? I replaced the belt and now I have lost speed/power. I can hardly get up the slight inclines in my yard in any gear higher than first. I think the belt needs tightened to grab the pulley better. Thanks
   / John Deere STX 46 drive belt #2
:welcome:
Is it a Deere belt?
   / John Deere STX 46 drive belt #4
Good.
Then I'd check the idlers to see if they have good bearings and none are loose.
Then check the tension spring to be sure it is pulling good tension on the belt when engaged.
I asked about the belt, because a substitute usually doesn't work.
I cant find any adjustment on the spring. It does need to be tightened. Do I need a new one, or could I cut some of this on off?
Thanks
   / John Deere STX 46 drive belt #6
Choice would be yours. But they are tough to shorten.
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A52472)
2013 3400QB...
JOHN DEERE 5083EN LOT NUMBER 136 (A53084)
JOHN DEERE 5083EN...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
2020 John Deere R4023 Sprayer (A53342)
2020 John Deere...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
2010 Chevrolet Equinox SUV (A51694)
2010 Chevrolet...
