Mowing John Deere STX 46 drive belt
   / John Deere STX 46 drive belt #1
jmbeaver
Point Pleasant, WV
John Deere
Is there any way to adjust/tighten the drive belt on a John Deere STX 46? I replaced the belt and now I have lost speed/power. I can hardly get up the slight inclines in my yard in any gear higher than first. I think the belt needs tightened to grab the pulley better. Thanks
   / John Deere STX 46 drive belt #2
:welcome:
Is it a Deere belt?
   / John Deere STX 46 drive belt #4
Good.
Then I'd check the idlers to see if they have good bearings and none are loose.
Then check the tension spring to be sure it is pulling good tension on the belt when engaged.
I asked about the belt, because a substitute usually doesn't work.
I cant find any adjustment on the spring. It does need to be tightened. Do I need a new one, or could I cut some of this on off?
   / John Deere STX 46 drive belt #6
Choice would be yours. But they are tough to shorten.
2017 JACTO ARBUS-1500 DIAM LOT NUMBER 66 (A53084)
2017 JACTO...
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
2010 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52576)
2010 PETERBILT 387...
2014 Ford Explorer Sport AWD SUV (A51694)
2014 Ford Explorer...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2013 FREIGHTLINER CASCADIA SLEEPER (A52576)
2013 FREIGHTLINER...
