John Deere Starting Problem
/ John Deere Starting Problem #1
helpfulbook
Bronze Member
Adirondacks, NY
John Deere 4700 Woods Backhoe 750, 460 Loader, Woodmaxx SB-72
Guys I'm stumped.
I have a JD 4700 Compact that sometimes turns over and wont start.
And sometimes wont turn over.
And sometimes starts with no problem.
I've changed Fuel shut off solenoid, starting relay, Blocking diode, Thermistor and ignition key switch.
If I hot wire the starter and take fuel solenoid off it will start and run fine.
I noticed that when I try to start with the key and have the fuel shut off solenoid out. The plunger "only sometimes" goes in and out.
When I hot wire the fuel shut off solenoid to a 12v battery the fuel shut off solenoid works every time.
Any suggestions would be appreciated?
Thank you,
George
/ John Deere Starting Problem #2
Sounds like a low voltage problem, or a bad ground. WARNING: Electrical Gremlins have been known to cause high blood pressure, hair loss, night sweats, and (of course) Cussing fits! :D Seriously, stuff like this can really drive you nuts.
Here's a couple things that I would check:
Battery cables, including the connection on both ends. My old 2600 was just starting when it wanted to. I took the clamp off to clean it, and when I put it back on, it broke. I replaced the cable, (got one at NAPA) and that fixed it. The old cable was corroded inside the insulation.
Load test the battery. I know it probably seems fine, but stranger things have happened.
Bigfoot62 , I made sure I cleaned the ground wire at the frame and battery connections.
Ok I'll test load the battery.
Thank you,
For the reply!
K7LN, Yes I think you guys are both right with the low voltage problem.
Does anyone know if these wiring harnesses can be purchase separately? (Like from starter switch to fuel solenoid to starter solenoid) etc.
I purchased this tractor used and I think it spent most of its life outside in the elements.
/ John Deere Starting Problem #5
Best thing to do is go to http://jdparts.deere.com, punch in your model number, and check out your schematics. Certain harnesses can be purchased separately and others cannot. It all depends on your tractor and the wiring. You should be able to see pretty easily by the diagram and you can price it out at the same time.
/ John Deere Starting Problem #6
So have you checked voltage on the fuel shutoff solenoid? It sounds like you may have an intermittent power issue going to the solenoid and the starter. If that solenoid is not moving the rack in and out with full power it will cause a crank no start.. The not turning over at all sometime is probably the same power issue, I would first try to find maybe a chaffed wire that is shorting to ground. My guess is that's your issue, your solenoid is good because when you put 12V to it she works perfectly.. Good luck..
I will the wiring schematics at the JDparts website.
atsah, Yes I did check the voltage. It drops down to 9.5v when I turn the key on.
I will check the wires between the fuel shut off solenoid and the starter.
Thank you
/ John Deere Starting Problem #9
some of those you can clean with a small wire brush, or sandpaper, others you can cut off the terminal and put a new one on. what ever you do, use NO-OX or Noalox on the connections before putting the together, and you will never have this problem again. it keeps the water and moisture out and stays there, and don't dry out!. these are found in the electrical department of most stores, to use for aluminum splices, it works fine for copper or steel, too!.
/ John Deere Starting Problem #10
John Deere has been selling special starting kits for garden tractor type machines. Likely would solve your problem as well.
High power needing stuff like a starter solenoid or a fuel cut off solenoid are being feed their power through many safety switches and electrical connections. When the power finally gets to say the starter solenoid there are not enough amps to pull in the solenoid.
The relay kit becomes the equivalent of jumping the starter without loosing all the safety features. The relay coil can operate on a poor electrical supply but then send full battery voltage to the required circuit.
This is a home made one on a Cub Cadet. An automotive headlight relay and 10 minutes of work.
Dave M7040
/ John Deere Starting Problem #11
Dave M7040
Yep, that's one way to bypass the problem!..
Will these kits for garden tractors fit my 4700?
I just got back from working on the tractor. It is definitely a short in the wiring harness coming out of the ignition. I'm just not sure witch wire it is.
When I move the whole harness it starts, move it again, it doesn't start. I took out the fuse panel like I had to when I replaced the thermistor. Move it around now it starts all the time. I know that didn't fix the problem will come back again.
So if this kit fits my tractor, it sounds like the way to go.
I want to thank every body on this thread for your help.
Dave M7040, Thanks for the idea and the pics!
/ John Deere Starting Problem #14
I made up a relay kit for my problematic diesel zero turn. Worked out perfect, so I made up another one for my primary zero turn.
Using a ready made kit will be easier, but you can make the same thing yourself for a lot less. I used the below instructions I found on an internet forum... perhaps even TBN.
Getting a photo error... I’ll try to find a link.
Google Image Result for https://www.mytractorforum.com/attachment.php?attachmentid=225122
/ John Deere Starting Problem #15
Yes open circuit, every time you move the harness you have a wire touching to make contact and then you hit a bump and you lose that connection. They can be a pain to trace if the harness is hard to get to..
/ John Deere Starting Problem #16
I'd actually unwrap the harness, and fix the wire, since it's not good at all to have a wire disconnecting, or shorting to another wire, NOT ground necessarily. although the one that shorts out could be on the other end of the relay power, and might need a ground, or open for the tractor to start, depending on the relay set up.. also, check that a wire was not pinched when you took out the fuse panel..
First I want to thank everyone for the help!
I have the fuse box out now and the tractor ran every time I started it all day while trying to find this problem.
So I had the tractor running and I tried to move the fuse box back into place and the tractor shut off.
So can anybody tell me if that narrows it down as to what fuse or relay that wire may be connected to?
Since it shut the tractor down when I moved the box?
That is something the tractor has not done before. Is shut down while it was running
/ John Deere Starting Problem #18
I would imagine you have a wire inside the connector that is loose, making contact, move the fuse box and not making contact, your close.. This is actually easier than trying to find a bad wire inside the harness "somewhere between the switch and the solenoid..
Can you visually inspect the connector that's going into the fuse box? I assume you can find the wire going to the solenoid by the amperage fuse.
Has to be the shutoff solenoid wire if it shutdown while running..
/ John Deere Starting Problem #19
one of the spade connectors or even a fuse holder is loose, that's the problem!.. all connections need to be snug, and clean!..
atsah, radios1 , You guys are like doctors working on a patient cross country!
I was just out here moving ONLY the fuses and I got the machine to start.
I kept playing with the fuses and fuse wires trying to get it to shut down but it would NOT.
It started raining so I stopped.
Will I damage those wires if I pull them out of the fuse and relay box from behind?
Thank you for the help guys.
2015 Ford Explorer AWD SUV (A61569)
2015 Ford Explorer...
New/Unused CFG Industrial NT18K Mini Excavator (A65583)
New/Unused CFG...
Case SV280B (A60462)
John Deere 2755 Boom Mowing Tractor (A66285)
John Deere 2755...
1994 John Deere 8300 (A64126)
1994 John Deere...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
