John deere shere pin size
/ John deere shere pin size #1
nod
Bronze Member
Can anybody tell me the size and grade bolt for a jd 1018 10' bushhog shear pin. Are they metric? 3/8's is to small and I sheared 2 of them today bush hogging. Does the bushhog have to be timed so the blades wont hit? I sheared a pin last year and replaced it without a problem with a 3/8 bolt grade 8. Every bolt I put in today sheared right off the bat?
/ John deere shere pin size #2
Are you engaging the PTO at idle?
You can probably find the operator's manual for your cutter online at Deere's website. It would give you the shear pin specs.
/ John deere shere pin size #3
Most shear pins are 1/2 inch bolt. Usually 3 or 3.5 inches long. Most people use the softest grade bolt.
I have already looked. You can buy one but nothing is free.
I was told last night that if it is john deere, it is metric? It is bigger than 3/8 but smaller than 7/16 so I guess they are right.
/ John deere shere pin size #6
10mm, is it a 8.8?
10mm, is it a 8.8?
Yes, 10mm and all the store had was 8.8. I guess i am OLD. I would have thought that it would not have been metric!
