John Deere Paint?
   / John Deere Paint?
Is the Factory JD paint in gallons ready to spray? What kind of paint is it, enamel? Kind of a one step? Just curious. I thought about the whole automotive type paint job I have not deicided yet what to do, I really want it to look like an original factory paint job. If you look at the pics above you can see I will probably need to strip it down to bare metal and then prime, but im up in the air if I should base coat clear or just one step it.
James
   / John Deere Paint? #12
prosperity said:
Since I don't have a paint gun setup....
I've used Deere spray paint with good success - seems to be very good paint.
In my most recent touch up, painting where my bucket hooks were welded on, I used a primer from Tractor Supply (Valspar Implement Paint Primer), then used the Deere green for the final coats - came out very well.
I've also used the Tractor Supply Implement paint for my trailer (black) - also seems like a good paint.
Years ago I fixed up an old 332 which was in similar shape as your 955 using Deere paint - with proper prep work, it came out pretty good.
Yes that paint is kinda pricey but it definitely is very good paint
   / John Deere Paint? #13
Get You A Gravity fed air Paint gun they are awesome & buy A gallon of Johndeere Green Paint & John Deere paint Thinner It will do great !
   / John Deere Paint? #14
tinman955 said:
It has 700 hours on it and has had service since new from dealership where he bought it. What manuals are must have for ownership of this 955?
The 955 is a great tractor...I have had several with FEL and b/h. You
need the owner's manual and the workshop manual (TM1360) is great to
have. The I&T after-mkt manual is only fair at best. Try Ebay and
consider the PDF versions if you want to save some $.
   / John Deere Paint?
Where can I find the PDF manuals? I looked on JD website and ofcourse couldnt find them, I find that their website is hard to navigate for some reason,lol. I really like the 955 it just looks bad but runs great. It was left outside for about the last 10 years which can just make a guy sick:( I havnt done much with it yet but I plan to start this week and go all over it.
I made the mistake and went with a buddy to go look at a 110 tlb and seen a 3720 :D :D :D cool turbo,lol.
   / John Deere Paint? #16
I would not suggest clear coat, it pukes on most cars/trucks over 7 years old and I have scraped/sanded lots of it off
not a good thing at all
   / John Deere Paint? #17
The BEST paint for the buck is at the John Deere dealer. It's PPG brand, packaged for Deere. It's the same acrylic enamel that's on the tractor. You'll pay double or triple the cost FOR THE VERY SAME PAINT at an auto paint supply house. It's the one thing Deere sells that's CHEAP. By staying with the brand/type that's already on the tractor, you minimize the possible complications of product incapatability. Not all paints will work over other types. There can be adverse reactions. I HIGHLY recommend using primer, paint, reducer, and hardener from same manufacturer. (remember that JD paint is PPG)
Paints from TSC are alkyd enamel and will quickly fade in sunlight compared to original paint.
Reducer (thinner) can be had through Deere, but isn't commonly stocked. Auto paint supply houses are a good source. NAPA sells Martin Seniour (sp?) brand. It's a good choice. Reducer from NAPA (for acrylic enamel) will work just fine. BE CAREFULL if you use hardener. It is VERY HARMFULL and/or LETHAL if exposed to enough of it. USe as directed. (Cover entire body/use fresh air breathing system...NOT a charcoal mask) I have symtoms of asthma from improper use of hardeners in VERY small dose.
Avoid uerethane (sp) enamels for the same reasons as hardeners. That, and they're tricky for a novice.
Clearcoat works best as part of a "system" (base coat/clear coat) They aren't all that complicated, but every step you add doubles the chance of problems. A novice painter needs simplicity, believe me. BTDT, got paint all over the T-shirt.
Single most important part of making a paint job look good is PREP WORK BEFORE THE PAINT FLIES!
   / John Deere Paint? #18
tinman955 said:
Where can I find the PDF manuals? I looked on JD website and ofcourse couldnt find them, I find that their website is hard to navigate for some reason,lol. .
You went to JDParts.com?
If you register, you can view the whole parts manual for your tractor
online. I bought a legal copy of it on CD from JD, but I do not remember
where I found it online. I found the PDF fiile of the service manual on
Ebay. JDParts.com is useful to get an ideal of parts pricing, but my
JD dealer beat the prices 98% of the time and I bought a LOT of parts.
Issues with the 955: front grille removal/replacement. Keeping
the HST pedal pivots properly lubed/adjusted. Electrical and mechanical
safety interlocks.
2002 Wacker RD11A Tandem Smooth Drum Roller (A54811)
2002 Wacker RD11A...
2008 CATERPILLAR 725 OFF ROAD WATER TRUCK (A51406)
2008 CATERPILLAR...
Pair 2 - ST225/75R15 radial trailer (A53421)
Pair 2 -...
4611 (A47477)
4611 (A47477)
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2015 Kubota RTV-X900 4x4 Utility Cart (A55787)
2015 Kubota...
