John Deere MFWD Clutch Pack Problems
/ John Deere MFWD Clutch Pack Problems #1
pstahl
Bow, NH
John Deere 5105M
I own a John Deere 2350. It has been stuck with the MFWD engaged since I have owned it. The solenoid works correctly and the pressure test indicates proper pressure and lack there of as per the specs. The clutch pack is now out and the spacer ring around the basket is clearly worn which will result in lack of disengagement. I also see wear in the clutch hub where the inner spline disks have worn a hollow where each one sits on the hub. I have not disassembled the clutch yet to look at the piston etc. However, my question is assuming the spacer and any other parts that effect the actuation and release of the clutch springs are working properly will the hollows worn by the inner spline disks on the hub prevent the clutch from disengaging? In other words, am I looking at a new gear and disks the former of which I suspect NLA.
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
2017 KUBOTA KX057-4 EXCAVATOR (A65053)
2017 KUBOTA...
2021 Redirective Crash Cushion Guardrail (A64556)
2021 Redirective...
2022 EZ-GO ELITE...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2019 Ford F-150...
E-Z TRAIL HEADER CART (A64278)
E-Z TRAIL HEADER...
