John Deere LX173 Won't Crank Blows Fuses
   / John Deere LX173 Won't Crank Blows Fuses #1
Seabeeman01
John Deere LX173
I have a John Deere LX173 that blows the fuses and won't crank . I put a used ignition switch on it after the old one started smoking . It looks like it burnt up a resistor or something on the old switch . Occasionally it will start with the key , but the last time I had it running I had to turn the key on and jump the starter solonoid . It has two 15 amp fuses on the ignition switch curcuit board , but I can't find what the fuses protect . Could I have a bad neutral safety switch ? I also changed the starter and this didn't help .
I figured it out . PTO SWITCH WAS BAD !!!
   / John Deere LX173 Won't Crank Blows Fuses #2
Good job. How did you figure out the pto switch was the problem?
The wiring diagram showed the power routed through the PTO switch , so I had a spare and installed it to see what happened . Starts right up now . I knew something had to be bad , either the neutral safety switch , seat switch wiring or what ever was fused in those 2 fuses in the ignition switch . Bypassing the seat and neutral switch didn't do it , so I went to the PTO switch .
It's interesting that even in the service manual , Deere doesn't state specifically what the fuses go to or what they protect without reading the wiring scematic .
STORAGE FEES (A54313)
2013 Road King 30ft T/A Boat Trailer (A51694)
2013 Road King...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52705)
KNOW BEFORE YOU...
2024 KMC 7406 (A53084)
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
