John Deere LX 178 Won't turn over
   / John Deere LX 178 Won't turn over #1
PHG JOHN
Pittsburgh, PA
JD LX178
My John Deere LX 178 just came back from dealership having new water pump installed. Ran fine for a day. Now it won't start. When I turn the key to the 2nd position, the starter starts cranking. (this should happen on position 3, not position 2). If I turn it to position 3, the starter wont shut off. Bad solenoid? Bad starter? Bad control board? HELP! Where do i start?
Thanks!
   / John Deere LX 178 Won't turn over #2
I would call the dealer and see what might be wrong. Cant see a water pump change doing anything to the start system other than unplugging connectors.
you might look at all the underhood connectors and make sure they are all tight.
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2007 Ford Five Hundred (A55758)
2007 Ford Five...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A55852)
2015 Peterbilt 320...
2002 WACKER RD25 ROLLER (A54607)
2002 WACKER RD25...
2013 MGS GODWIN CS150M DRI PRIME PUMPING UNIT (A51406)
2013 MGS GODWIN...
2019 PETERBILT 579 TANDEM AXLE SLEEPER TRUCK (A54607)
2019 PETERBILT 579...
