John Deere LX 173
   / John Deere LX 173 #1
radka
rental
I am considering purchasing a riding lawn mower (John Deere LX 173 ) and the owner states that it only moves in reverse. What are the costs and mechanical ability needed to repair this small tractor with the forward gears already out of commission.
Thank you for your time
J.R.:)
   / John Deere LX 173 #4
Hey Radka! Welcome to TractorByNet! :D I have moved your thread to the John Deere Buying/Pricing Forum. You will have better luck finding assistance there. :thumbsup:
   / John Deere LX 173 #5
The lx173 is a good LAWN tractor (not designed for ground engaging implements). I have one that we use to cut the yard, places the tractor won't go, pull a small sprayer, etc. We bought it used (abused?), changed the oil, sharpened the blades and it has been pretty much problem free for several years. EXCEPT..... :D It likes to jump out of reverse some times.
Your problem could be a lot of things - anything from the shift linkage needing adjustment to the transaxle being fried. Hard to tell without looking at it.
When you try to put it in forward gear, does it make a ratchety, clacking noise? The transaxle uses shift dogs (like little square keys) that slide into collars on the gears to engage them. With wear, age, use, etc, the shoulders on the gears and the profiles of the keys round off, making it pop out of gear, then eventually fail to engage at all. Usually only happens with first couple forward gears and/or reverse though. If this is the problem, can split the transaxle and replace keys and clean up/replace gears (parts are available).
OR - it was a fairly common transaxle used on a lot of different lawn tractors - just get a used one from "that online auction site." Depending on the deal, you may pick one up for $40-50. Easy bolt in/bolt out switch over.
IF you look around, you might find a whole "parts" tractor for cheap. I bought one with a blown motor for $25.00, so will eventually swap out the transaxles when my reverse becomes a problem.
The series were good well built "old style" mowers - one in decent shape would be head and shoulders above a new box store model. They would support a front mounted snowblower, tiller, and of course a mower deck.
Hope that helps!
2016 Hino 195h Truck, VIN # JHHSPM2H9GK001609 (A51572)
2016 Hino 195h...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2024 JOHN DEERE FC 10 R LOT NUMBER 84 (A53084)
2024 JOHN DEERE FC...
Ingersoll Rand Air Compressor (A51573)
Ingersoll Rand Air...
JLG 1930ES ELECTRIC SCISSOR MAN LIFT (A51246)
JLG 1930ES...
