John Deere LT160 won't crank when I turn the key.
   / John Deere LT160 won't crank when I turn the key. #1
Joel Blevins
Tunnel Hill, GA
John Deere LT160
I have a new battery this summer, 500 plus hours on mower. When I turn the ignition key, nothing. Could someone give me the sequence to locate the problem? I'm thinking starter solenoid or starter or safety switch related to brake/seat sensor?
   / John Deere LT160 won't crank when I turn the key. #2
I have an LT160, there are three safety switches. There is one on the pto, one on the seat(these two are the same style) and one on the break (that one is different).
I have over the years had to swap them all and this year i did replace the solenoid. Price wise I would start with getting three switches and seeing if its that. They seem to go and I keep a few on hand now. THat way you will know if its the solenoid which is an easy fix too.
Btw welcome to tbn.
   / John Deere LT160 won't crank when I turn the key. #3
I would start be jumping directly to the solenoid to test the solenoid and starter. After that jump each safety interlock till the problem is found. The interlocks can be tested with a test light for power or disconnected and tested with an ohm meter. The normal problem is an interlock.
   / John Deere LT160 won't crank when I turn the key. #4
Make sure you check fuses. The primary fuse to check is what appears to be on Ground Wires (black wires). This is the fuse. You can jump from each connector after removing this fuse and if the engine starts, that is your problem. To fix mine I just made up an inline automotive fuse so I could check it later if I have another problem.
   / John Deere LT160 won't crank when I turn the key. #5
:welcome: to TBN rfleming
Note that the thread was started about 4 years ago. But sometimes it is easy to miss that... ;)
Clever idea you have..
   / John Deere LT160 won't crank when I turn the key. #6
I did see that but when I searched (Googled) for LT160 won't crank, I found this page. I was just hoping it would help the next guy if he found this page too.
   / John Deere LT160 won't crank when I turn the key. #7
Good reasoning... :thumbsup:
UNUSED FUTURE ML32 - 32" HYD MULCHER (A51248)
UNUSED FUTURE ML32...
2007 Chevrolet Impala Sedan (A51694)
2007 Chevrolet...
WESSEX CRX 240 LOT IDENTIFIER 156 (A53084)
WESSEX CRX 240 LOT...
UNUSED CHERY INDUSTRIAL 20' BI-PARTING IRON GATE (A51248)
UNUSED CHERY...
2006 HAMM HD120HV SMOOTH DOUBLE DRUM ROLLER (A51246)
2006 HAMM HD120HV...
