John Deere LT160 bogs down???
   / John Deere LT160 bogs down??? #1
presa canario
Tractor was running perfect until several days ago while I was leaf collection and now the tractor isn't running properly.
-The tractor bogs down especially at high RPM's
-It will start and run but the egine almost seems to sputter
-When I pulled and changed the plug it was dry and black (I assume thats carbon)
These are the thing I already did with no luck.
-Changed the air filter, fuel filter, spark plug, recently changed the oil, quickly sprayed carb cleaner in the carb, removed the gas cap (and ran the engine), removed the entire air filter assembly (and ran the engine.)
Any ideas??
   / John Deere LT160 bogs down??? #2
Follow the fuel line, maybe you got a kink or bad spot. You may need to replace it.
Replaced the fuel, went through it again and still at high RPM's it surges.
At 1/2 throttle - down to idle it runs perfect. About 3/4 throttle up it surges and black smoke sputters out.
Any thoughts:confused:
   / John Deere LT160 bogs down??? #4
sounds like something in the carberator. I would take it apart and rebuild it.
2014 John Deere 544K 2 Wheel Loader (A47384)
2014 John Deere...
2025 LandHonor PF-11-3500G 4,000lbs 42in Pallet Fork Skid Steer Attachment (A49462)
2025 LandHonor...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2008 John Deere 2305 Tractor (A50514)
2008 John Deere...
JOHN DEERE 9650 COMBINE (A51243)
JOHN DEERE 9650...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
