John Deere L120 Leaking Oil when mowing HELP!!
   / John Deere L120 Leaking Oil when mowing HELP!! #1
CountryGirlCityGirl
middleport, ny
john deere 790
I have an John Deere L120 that is leaking oil when its mowing not in ideal, the leak is onthe left side (if sitting on mower its on the left) It starts out fine but then starts to smoke white smoke. When cool oil level is fine, could it be a head gasket??? Heard that from another forum. HELP!
   / John Deere L120 Leaking Oil when mowing HELP!! #2
Sounds like oil may be dripping onto the muffler when running. Most likely area to leak and do that is the valve cover gasket. Other possibly area could be the sump gasket leaking and then running across the frame and then on the muffler. could be head gasket, but is is rare for the head gasket to leak externally. Normally leaks between the cylinder wall and the push rod cavity in the block.
2017 Ford F-250 Reading Service Truck (A48081)
2017 Ford F-250...
2018 Hyundai Sonata Sedan (A48082)
2018 Hyundai...
2007 Vanguard National VIP4000 53ft. T/A Dry Van Trailer (A48081)
2007 Vanguard...
Two Seater Pontoon (A48837)
Two Seater Pontoon...
2011 Nissan Juke SUV (A48082)
2011 Nissan Juke...
2018 Ram 5500 Bucket Truck 4x4 with Versalift VST40 - 45FT Rotating Bucket and Jib Winch (A50397)
2018 Ram 5500...
