John Deere JD400 service manual
   / John Deere JD400 service manual #11
Try bending some coat hanger wire or something similar to catch a piece of that screen and pull it out.
Alex
   / John Deere JD400 service manual #12
Alex
Well, I may have screwed the pooch in this one. It's what I get for trying to work on hydraulics and knowing nothing about it. The plug I took out to get to the screen wasn't for the screen. I finally got what I thought was the screen out and it ended up being a valve. The best way to describe what came out was it was like a large version of a forward/reverse piston in an air impact gun. I put it back in but it had a key way or notches about mid way through and I'm not sure if I messed up whatever went in there. I THOUGHT I was going for sort of a cartridge screen type thing but stopped and thought about it and realized it was simply a tube screen and that it was right there where the house goes in. It is out and cleaned now but I think that may be useless now. The plug and valve I mistakenly took out is almost directly above the vertically mounted filter cartridge and is about 6" long. Any help or advice would be greatly appreciated!
   / John Deere JD400 service manual #13
Are you referring to valve(parts key 3)? That's the hyd filter relief valve. If so it needed to be removed also especially if it was stuck open.
   / John Deere JD400 service manual #14
Yes, I hadn't been back on the computer, only my phone, so I couldn't see the picture. It was the relief valve
   / John Deere JD400 service manual #15
Only the valve part came out nothing behind it. Thanks for the reply, I don't feel as bad now about possibly ruining the transmission
   / John Deere JD400 service manual #16
I would strongly suggest buying the service manual from John Deere. If you go online you can download it instantly in PDF format, or order in on CD, or order a paper manual.
   / John Deere JD400 service manual #17
Thanks for the help. I got it all back together and found the sectionals on JDparts. I'll order a manual later this week. Still have the same problem I had before I started. Blew another O ring out. Once I get the manual I'll try to tackle it again. Hard to even describe problem I'm having when I don't know the name of the part having the problem,lol
Case 586H (A50120)
Case 586H (A50120)
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
66in Light Material Bucket Skid Steer Connection (A52748)
66in Light...
(4) 3 PLUG VALVES (A52472)
(4) 3 PLUG VALVES...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2020 FREIGHTLINER...
