I am new to this list so bare with me.
I have owned this tractor since new in 1998. aprox 650 hrs on it. Up untill this year, I had never used the float position on the loader. To tell the truth I never new what it was.
When I tried it, it seemed to work fine. The next day I used it again, when I tried to dump the bucket, it would barely tip forward. I have removed the scv valve to clean and inspect it before replacing the hydraulic fluid. The valve spools are spotless and the end springs are clean w/no rust or dirt.
When this happened, the bucket would raise and lower with normal engine sound but would sound a little like a drag on the engine when the scv was in the neutral position. Is it possible that the spool could be stuck in a partial float position?
I retired from the auto repair business after 44 years so I understand hydraulics, just not tractors. The valve is still apart as I think I am not seeing the problem. As a side note, I have an scv apart from a Kabota that had a similar symptom that turned out to have a corroded housing on the end of the spool.
Any help would be much appreciated. Ray
