John Deere HD rotary mower - 09 series?
   / John Deere HD rotary mower - 09 series? #11
I am thinking about a Rhino TR96, very heavy built. Just have not had a chance to price one yet. Triple gear boxes don't scare me. Only draw back I see is more blades to buy.
Those trees sound more like cut and pull than mow.
Yup... some definitely will be! More likely will be root, grab and pull - with my 110TLB - or a small excavator.
Really liked a JD 50D I rented last fall. Amazing how that small an excavator can tackle some really big trees - and win!
AKfish
   / John Deere HD rotary mower - 09 series? #13
Alot would depend on how much of this you have to do and how fast you need it done. I would also consider a large chipper behind the tractor and use the 110 to pull the stumps. When clearing in my area the cost of debris removal can be upwards of $14/yd, so being able to chip everything and have it break down quickly and easily is a real plus. Also reduces the amount of time hauling and handling too. I like the fact that in a very short time of a week or so the cleared land is ready to use.
I can easily see running a shredder over larger areas is faster but it still leaves a mess and takes time to break down and rot everything enough for a hayfield.
Takes forever to break the woody debris down! Likely 3-4 years at least and the hay yield is quite a bit lower.
Burning, bury or haul it off. Burning is a liability nightmare, burying messes up the field and hauling is very expensive up here, too. Trick is to find a location that will accept the material. Landfill won't take that stuff -- way, way too much space required and if one person is allowed -- there'd be no end to it!
Everything considered; it's easiest to just chew up as much as possible and leave it in the field to rot. Great field in 5 years!
AKfish
   / John Deere HD rotary mower - 09 series? #15
AKfish,
You could add some 39-0-0 fertilizer to the debris to speed up the break down.
   / John Deere HD rotary mower - 09 series? #16
What did you end up buying?
I am looking at a used 609. I am not sure it will work on my 4520.
D.
D.
A new tractor and HD 8' rear blade... :D
I backed out of the hay field rennovation job. Maybe next year. There's lots and lots of scrub trees that will have to be dealt with - thicker' than dog hair!
Likely take 3 years at the very least, before I could expect any kind of hay crop.
Might be pushin' things a bit with the 609... you've got 45hp @ pto, yes? Right on the edge - likely be OK if you don't tackle half-growed trees!! :eek:
AKfish
   / John Deere HD rotary mower - 09 series? #18
Dusty,
I just posted under "Attachments" with a question about a Deere 709 and the blade options. I've got a nearly new machine and the cut is pretty rough. Any thoughts?
(APPROX 15) 6" X 2" X 68" TUBING (A54756)
(APPROX 15) 6" X...
(49) 2" X 3" X 19" TUBING (A54756)
(49) 2" X 3" X 19"...
1065 (A53342)
1065 (A53342)
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A53472)
2000 John Deere...
UNUSED IRANCH EXCAVATOR ATTACHMENT SET (A54757)
UNUSED IRANCH...
New JMR 66" Skidloader Grapple (A50775)
New JMR 66"...
