John Deere GX345 hydraulic issues
   / John Deere GX345 hydraulic issues #1
wsmbgm
John Deere GX345
My John Deere GX345 has hydraulic problems. When first starting, the power steering and deck lift are noisy and slow to react. This improves some after warming up. It is important to note the transaxle/transmission works fine without any issues! The hydraulic fluid has been changed along with both hydraulic filters on a regular basis with JD Hygard low vis. I've owned the unit for about 13 years and it has less than 600 hours on it. With the price of JD parts, I hate to go through the process of elimination on changing out parts. Any help would be appreciated.
   / John Deere GX345 hydraulic issues #2
:welcome: to TBN
Can you give us some idea what the "noise" is like? rattle? buzz? high-pitched/frequency? low frequency? sound changes with change in rpm?
Always had this noise, or just recent? reason for changing the fluid and filters was the noise? noise before/after changing fluid?
Need some help from you.. How about a video with audio via YouTube?
:welcome: to TBN
More of a high pitched whine, filters and fluid always changed every other year as part of normal PM, started middle of last season. Steering hard and deck lift slow until warm and then improves some but noise does not improve. Noise is only when turning or lifting deck. As previously stated, transmission quiet and functions properly.
(Not very techie with you tube audio/video)
Thanks for the response.
UNUSED Roof Thermal Insulation (A50860)
UNUSED Roof...
2002 International 4400 SBA 4x2 (A49461)
2002 International...
71057 (A49346)
71057 (A49346)
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A51039)
2019 Tico Yard...
2021 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A50323)
2021 Toyota Tacoma...
2021 Kubota SVL97-2HFC Compact Track Loader (A50657)
2021 Kubota...
