John Deere F935 Just stopped moving
   / John Deere F935 Just stopped moving #1
treedigger
John Deere F935 & 855
I have a F935 that just stopped moving and lost all hydraulics while mowing.It has a Sundstrand Series 15 transmission. It was not losing power it just stopped while going from forward to reverse. The mower was working fine and then just stopped moving. At the same time the steering stopped working and the lift for the deck stopped. Engine runs fine and pto works. Drive shaft is turning the charge pump. I have taken the charge pump out and checked it. When I did a charge pump pressure test it only has about 15lbs. While it was out changed the seal, bearing, o-ring and pin. Inspected pump for wear and damage and everything looks fine. Checked and cleaned charge, implement and steering relief valves. I also changed the filter. I still have no hydro. Like I said everything was working great right up to the time it stopped. I think something come apart in the transmission itself. Any help or Ideas would be appreciated. Thanks, Craig
   / John Deere F935 Just stopped moving #2
Are the pressure relief valve button(s) pushed in? These have been known to leak and end the hydraulic pressure.
Thanks for the reply. I have checked them and and they are fine.
2019 Ford F-350 4x4 Crew Cab AutoCrane EHCPRX 3,200lb. 1.5 Ton Crane Mechanics Truck (A50323)
2019 Ford F-350...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A52748)
LIKE NEW 2023...
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A52748)
Hay Van FL-95 Bale...
Deere 333G (A50120)
Deere 333G (A50120)
