John Deere F725 Deck Engage Button
   / John Deere F725 Deck Engage Button #1
BrownBear
I recently bought a John Deere F725. I was mowing with it and it was going along just fine. Then I shut it off to put more gas in (had sent someone to go get more while I began mowing). When I started it again, it fired up, but the mowing deck would not engage when I pulled the yellow control switch. I shut it off and took a look. The drive belt and mower deck belt had both slipped off the pulleys. I got both back on just fine. I figured that was the problem, but when I tried to engage the deck, again the blades wouldn't turn. The mower starts and goes, but the drive belt for the deck underneath the mower won't even try to budge. I'm assuming it's an issue with the pull switch. Anybody have a better idea as to what the problem could be? ( and no, I don't have the parking brake on)
   / John Deere F725 Deck Engage Button #2
Did you do this?????? If you shut off the mower without pushing the yellow swithc down first then you are in a (SAFETY START MODE) all you have to do is push the switch down (OFF), start the mower and raise the switch up (ON) and it should run. Try that and get back to us. Make sure you are sitting in the seat for this test.
I tried that, but it still won't engage.
Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
Turfco...
2023 Ford Explorer AWD SUV (A51694)
2023 Ford Explorer...
2014 Mack CXU613 T/A Day Cab Truck Tractor (A50323)
2014 Mack CXU613...
2013 Hyundai Sonata Hybrid Sedan (A50324)
2013 Hyundai...
2016 Dodge Ram 2500 (A50120)
2016 Dodge Ram...
2012 Ford Edge SUV (A50324)
2012 Ford Edge SUV...
