John Deere DTAC 62233 - noisy steering
   / John Deere DTAC 62233 - noisy steering #1
JD5210
Veteran Member
Virginia
5210 MFWD
Other than contacting a John Deere dealership can someone provide me some information on DTAC 62233? I have a 99 5210, when I am operating the tractor over 2,000 rpm and turn the steering wheel either direction it makes a whiny noisy. The noise is coming from the steering wheel valve. I have changed the hydraulic fluid, filter and cleaned the pick screen, which has had no effect.
   / John Deere DTAC 62233 - noisy steering #2
Have you considered a friction modifier?
TY27807
JD has one, and I've used it to help the tranny in my 4x2 gator. Have no idea if it would help your steering noise. Just a thought.
   / John Deere DTAC 62233 - noisy steering #3
Are you sure of the dtac solution number? I did a search and that number doesn’t seem to exist. It is possible Deere removed it if they thought it was no longer a good solution. Have you checked steering and hydraulic pressures? Also look at all hydraulic lines to see if there are any lines touching anything that they could vibrate against.
2008 CATERPILLAR M322D MOBILE EXCAVATOR (A51406)
2008 CATERPILLAR...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
2013 Ford F-150 Pickup Truck, VIN # 1FTFW1EFXDFB07930 (A51572)
2013 Ford F-150...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
2007 International 7400 Chassis Truck, VIN # 1HTWGAAR87J437650 (A51572)
2007 International...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
