John Deere D130 will not start. Turn key get NOTHING, no click, no noise.
   / John Deere D130 will not start. Turn key get NOTHING, no click, no noise. #1
JDRTA
BRISTOL, CT
D130
My D130 will not start, will not crank the motor when key is turned on. Battery is good and lights are bright when on. With key on, when I jump from battery + to starter solenoid the motor cranks and starts (seat switch is depressed). The break switch and 20 amp fuse have been replaced. Suggestions appreciated.
I finally figured out what was wrong. I had checked two of the three safety switches, the ones usually mentioned in Threads. MY PROBLEM WAS A THIRD SWITCH, THE PTO SWITCH. It's the same as the break switch but behind the Push to Operate Lever for the cutting blades. Lift the hood and look under the PTO lever where the linkage pushes the switch.
   / John Deere D130 will not start. Turn key get NOTHING, no click, no noise. #3
BTW - Welcome to TractorByNet. I think, when you can diagnose a problem, like you had, all by yourself - you are well on the way to being a "tractor person".
   / John Deere D130 will not start. Turn key get NOTHING, no click, no noise. #4
Good job !!
   / John Deere D130 will not start. Turn key get NOTHING, no click, no noise. #5
Oh thank you .you saved me headaches and money .the push button was off center a little and i already checked the other 2.So thanks again!
(4) STEEL CARTS W/ WHEELS (A51248)
(4) STEEL CARTS W/...
DEWALT 4400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 4400 PSI...
2016 JOHN DEERE R4038 LOT IDENTIFIER 181 (A53084)
2016 JOHN DEERE...
UNUSED HURRICANE D6028 - 5' JOB BOX (A51248)
UNUSED HURRICANE...
RYOBI 3300 PSI GAS PRESSURE WASHER (A51248)
RYOBI 3300 PSI GAS...
2024 Dig Master DM-F20 Electric Fork Lift, NEW! (A52384)
2024 Dig Master...
