john deere battery
/ john deere battery #1
james322
jd 790
i have a 790 10 months old with 45.8 hours and the battery is eating the hold down and eating the paint off some sheet metal . will john deere repair this under warranty.
/ john deere battery #2
They have done that for others.
But the cure is spelled O P T I M A...
i dont mind buying a good sealed battery or fitting a box but i would like to have the sheet metal replaced if they will .
/ john deere battery #4
If your 790 is only ten months old, it does have a two year warranty. The condition you describe is a warranty situation and should be dealt with before the damage is more extensive. You might ask your Dealer Service Manager to check for any DTAC solutions for the condition you describe. /forums/images/graemlins/smile.gif
/ john deere battery #5
Yes they will fix it if the battery is what caused the problem.
/ john deere battery #6
Yup, let them fix it. But they will want to give you another JD battery. Even the "won't ever happen again with this battery" replacements seem to have the same issues. (And not just Deere is having this problem...)
The best fix I have found is getting the Optima. Even though it is money out of your pocket, it is better than having to transport the tractor back for service, and loss of use, or my time repairing damage.
Our weather has been crazy /forums/images/graemlins/shocked.gif with one day 65, the next is 12, and back to 65... But no matter how cold, the tractor starts right up, and no more leaks!!!!
i talked to the owner of the company today and he reffered me to his service tech and he said he would contact john deere and see what they will do and get back to me .
/ john deere battery #8
Maybe this can help?Quick fix for the people who can't afford a new optima battery. You can use a square plastic pail and cut it to fit your battery this will hold the acid when it leaks.Also the fan can't pull the acid off the battery. I used a cat litter pail with the battery in it, then trim off the plastic to fit the area. I used this on my 212.
/ john deere battery #9
I had the battery leak my 4310. At the time that it happened, I did not know about this forum or Optima, so JD replaced it with another battery and also had to replace the hydraulic cooler.
Looks like from what I am hearing here, that I will have to keep a close eye on it and think about buying an Optima.
Are they available in Canada.
Thanks
Richard
/ john deere battery #10
I just gave up this week and put an Optima in my 4400. My first JD battery lasted less than a year, and they replaced it for free. The battery now is two years old tops. This summer I pulled it, serviced it, and cleaned the corrosion on the battery tray. I cleaned and repainted the corrosion on the tray last night, and put the 130 dollar optima in. I could not find a direct bolt in replacement for the 22NF series battery in the Optima line, so I had to build a batttery bracket.
I also noticed some acid or something ate part of the plasatic wire wrap, so I fixed that. /forums/images/graemlins/frown.gif
Wayne
i did not hear from the dealer or service manager today i will call again thursday. if they dont fix the corrosion i will repair and repaint it myself and buy a good battery even if they replace the battery.
/ john deere battery #12
James- If JD will replace the battery, let them do it, then buy an Optima and install it. Never hurts to have a spare battery, just keep it charged and ready to go.....
/ john deere battery #13
Guest what,after no. 2 battery from jd I took that leaker and put it in my son car 1991 honda and it stop leaking.Do we all have the same problem????Years ago had the same problem with my 212,the b/rectifier was bad and made the battery over charge and acid went all over the place. Maybe we all have a design problem???? /forums/images/graemlins/frown.gif /forums/images/graemlins/confused.gif
/ john deere battery #14
I have been lucky - 2 years for my 790 in March and no leaks.
/ john deere battery #15
If I may enter an opinion here. The problem is not with the battery overcharging. The problem is the location of the battery in front of the radiator/oil cooler. The engine fan will pull the corrosive fumes from the battery area and suck them through the cooler and radiator. By going to a sealed battery (or a battery with non vented caps) you eliminate the fume problem and the corrosion will stop in most cases. This information is paraphrased from a DTAC solution describing a Product Improvement Program on 4000 series JD CUTs. Made sense to me. /forums/images/graemlins/smirk.gif
/ john deere battery #16
Make the switch to an Optima. You won't regret it. I got my yellow top from the nice folks at www.remybattery.com.
No more leaks or corrosion. Definitely money well spent.
In all fairness to JD, my strongbox did last six years.
/ john deere battery #17
I get none of that with my tractor and the fan pulls just like you mention. I have 400 hours and my radiator and oil cooloer are clean enough to eat off of. Neither the positive or negative terminals have even the slightest sign of corrosion. My neighbors JD 790 with 100 hours looks great on the outside, the battery compartment looks like a war zone. He did not even bother to go to the dealer, he just went to NAPA and picked up one of their batteries. Problem eliminated, the carnage left by the original battery is still quite apparent. Both of the factory cable ends rotted away and he has the clamp on style now which I don't like much but they are certainly a less expensive and a quick repair. Optima or other brands of sealed batteies are a good option and one that unfourtunarely is typically made after the damage has started.
T/A Dovetail Flatbed Equipment Trailer (A66736)
T/A Dovetail...
2005 COMPTANK ACID TRANSPORT TRAILER (A67714)
2005 COMPTANK ACID...
2010 48 ROLL OFF TRAILER (A65643)
2010 48 ROLL OFF...
2013 TYTAL CRUDE TRAILER (A67714)
2013 TYTAL CRUDE...
2019 KOHLER 38RCL Generator DISCONNECT ATS 38KW 315 HORS (A66734)
2019 KOHLER 38RCL...
2014 Chevrolet Impala Limited Sedan (A66738)
2014 Chevrolet...
