John Deere 955 with FEL..... I want to install a grapple
   / John Deere 955 with FEL..... I want to install a grapple #11
You'd also have to buy an open center valve to create the remotes
The O-ring Boss fittings can be sourced from a hydraulic supply house, the set screw id have to remove to get the exact size and thread, I'd be easier though if I new what year that tractor was , the serial # decoded will tell me
Sounds good! I want to do this. I'll get the serial number this week sometime and make a parts list. Then I will write up the installation on here.
Been thinking of just welding up my own grapple for my standard bucket. After pricing out a few, that 48" titan weighs 450 pounds and costs $1100. I think the Green Thumb will be in the neighborhood of $600 after buying the thumb($400), installation mount($135), and cylinder(~$80). I mean $525 for that makes me a little sick to my stomach. I think I would just rather buy some tubing and make something like this to be honest:
I have a Mechanical Engineering background.
   / John Deere 955 with FEL..... I want to install a grapple #13
If you have basic welding skills and some metal tools (or a metal shop that can cut stock to your specifications) then you shouldn't have any trouble making a jaw for your standard bucket. Lots of designs to copy. Lots of threads here on TBN of guys doing that. As I noted earlier, a full grapple is more efficient especially at digging out stumps and things like that but for carrying brush and branches, a grapple bucket would be fine and much less hassle and expense.
One other thing, I doubt the Titan 48" grapple is 450lbs. My 48" Millonzi (no longer made) weighs in at about 300-320 and is made of the same 3/8" steel and 1/4" square tube. The EA Compact grapple weighs only about 250lbs or something like that and is made of 5/16 high test steel. Your focus on weight is very appropriate though.
   / John Deere 955 with FEL..... I want to install a grapple #14
I bought Greens Machine Thumb, for what it would take to build it myself time wise it wasn't worth it , and I'm happy with the product !
I'm thinking the same thing....
   / John Deere 955 with FEL..... I want to install a grapple #16
I have a grapple on my old Satoh Beaver that we cobbled up from some scrap C channel, angle iron, and a thumb I purchased on e-bay. Not as strong as soem offerings but it works pretty **** well. Just dont' expect it to look pretty. It doesn't. :D
Well, I finally got it done! Used a surplus center diverted valve, KTM dirt bike waterproof kill switch, green machines 24" grapple, and custom hoses from the local John Deere dealer. Works amazing. I added some plate steel for some low cost timber teeth to hold logs. Works great and here are some pictures! Thanks for the help everyone.
   / John Deere 955 with FEL..... I want to install a grapple #18
That's cool. Thanks for posting and the pics.
A bit envious, as I'd like to put a single thumb on my Deere forks. Will have to fabricate, as cannot find a single thumb.
   / John Deere 955 with FEL..... I want to install a grapple #20
The total amount of hand work in that single grapple load is indeed immeasurable. :thumbsup:
2025 GIYI MULCHER SKID STEER ATTACHMENT (A58214)
2025 GIYI MULCHER...
2015 Infiniti QX60 SUV (A56859)
2015 Infiniti QX60...
202482 (A54757)
202482 (A54757)
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
