John Deere 870 gauges issue
   / John Deere 870 gauges issue #1
StevenM6080
John Deere 870
My JD 870 has a mysterious issue. The fuel and temperature gauges only work when there has been rain or the tractor is wet. I assume this is a ground issue but can't figure out where to find the problem.
Any help or guidance would be appreciated.
Thanks Steve
   / John Deere 870 gauges issue #2
Welcome to TBN Steve :D
That is one odd problem you have there for sure. You may be correct on the ground problem-no way to find out without starting to take everything apart.
You may want to consider getting the FSM from JD: John Deere Technical Information Bookstore - Home Page
   / John Deere 870 gauges issue #3
G'day steve run a small jump wire from the eng block to the -ve side of the battery and if the temp gauge works then you have an earth ( sorry ground ) prob but if both gauges are not working then i think you have a voltage supply problem, probably a voltage stabiliser behind the dash and it is getting damp air in it to make contact. Hope this helps
Jon
Thanks for the suggestion-I will try it and report back.
Steve
Well I cleaned out the battery compartment and cables. The fuel gauge is working but the temp qauge isn't. The jumper on the negative to the chassis doesn't do anything. I am baffled?????
Steve
   / John Deere 870 gauges issue #6
G'day steve take the wire of the coolant sender and short to ground with the ign on engine off and the needle should go to hot if it does then sender no good see how you go
Jon
WEll now I need to search for the coolant sender-may clues or suggestions.
Thanks for all your help.
Steve
Woods BW12 Batwing Mower (A50514)
Woods BW12 Batwing...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2019 INTERNATIONAL...
2012 Ford F150 Crew Cab Pickup Truck (A50323)
2012 Ford F150...
2019 FORD F-350 SERVICE TRUCK(INOPERABLE) (A50854)
2019 FORD F-350...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
John Deere 1100 3 pt Field Cultivator (A50514)
John Deere 1100 3...
