John Deere 870 gauges issue
   / John Deere 870 gauges issue #1
StevenM6080
John Deere 870
My JD 870 has a mysterious issue. The fuel and temperature gauges only work when there has been rain or the tractor is wet. I assume this is a ground issue but can't figure out where to find the problem.
Any help or guidance would be appreciated.
Thanks Steve
   / John Deere 870 gauges issue #2
Welcome to TBN Steve :D
That is one odd problem you have there for sure. You may be correct on the ground problem-no way to find out without starting to take everything apart.
You may want to consider getting the FSM from JD: John Deere Technical Information Bookstore - Home Page
   / John Deere 870 gauges issue #3
G'day steve run a small jump wire from the eng block to the -ve side of the battery and if the temp gauge works then you have an earth ( sorry ground ) prob but if both gauges are not working then i think you have a voltage supply problem, probably a voltage stabiliser behind the dash and it is getting damp air in it to make contact. Hope this helps
Jon
Thanks for the suggestion-I will try it and report back.
Steve
Well I cleaned out the battery compartment and cables. The fuel gauge is working but the temp qauge isn't. The jumper on the negative to the chassis doesn't do anything. I am baffled?????
Steve
   / John Deere 870 gauges issue #6
G'day steve take the wire of the coolant sender and short to ground with the ign on engine off and the needle should go to hot if it does then sender no good see how you go
Jon
WEll now I need to search for the coolant sender-may clues or suggestions.
Thanks for all your help.
Steve
2021 Caterpillar 304E2 Mini Excavator (A50322)
2021 Caterpillar...
2007 FREIGHTLINER COLUMBIA SLEEPER (A51222)
2007 FREIGHTLINER...
2015 DODGE RAM...
2021 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A50323)
2021 Toyota Tacoma...
2008 FORD F-350 (A50854)
2008 FORD F-350...
71065 (A49346)
71065 (A49346)
