john deere 870 front drive shaft reinstall
   / john deere 870 front drive shaft reinstall #1
Sberry
Platinum Member
Brethren, MI
Mostly green
The spring is really strong , how do I hoist the driveshaft back up in it? It seems like a stif effort going to be required to compress the spring that far while holding it up for installation.
   / john deere 870 front drive shaft reinstall #2
I don't know the 870 but on the 850 you can pull the pin and take the tension off the spring pack the collar with grease, install the bearings and apply the spring tension then replace the pin.
Its so tight, I made a tool, wasnt without sone effort and could improve it on the outside chance I got to do one again. Even getting it in place was a challenge, took couple of us a few minutes of fiddling turning and timing a little and all of a sudden falls together
2015 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
198367 (A51243)
198367 (A51243)
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
