John Deere 855, twisted frame or tansmission adjustment
   / John Deere 855, twisted frame or tansmission adjustment #1
sampwell
JD 855 1987
Hi,
i'm not very good in english, i will try to explain the problem
I have a JD 855 1987, i'm building my front end loader.
I have build boom and braket left and right same size etc.
when i'm installing it, the right side of boom and bucket are 1" too low.
Ive cheak with a beam level.
when a check the front frame and i jack it to lever if i cheak the lever of the transmission it's not level.
doest the transmission and cab are adjustable or i have a twisted frame?
Thanks
   / John Deere 855, twisted frame or tansmission adjustment #2
Start with the simple stuff first, are your tires air up to the correct pressure? I thought my FEL was out of level by about an inch, it turned out to be a rear tire a few psi lower than the other rear tire....
Yes i have 28 psi rear and 34 psi front
   / John Deere 855, twisted frame or tansmission adjustment #4
Rather than pressure, use a tape measure to measure to the center of the axle.
MANY people report buying tires that are the same manufacturer, but inflate to different diameters.
I always air my rear tires on my tractors with a tape measure,, not a pressure gauge.
The front tires do not matter, as the axle pivots,,,
LOT: (100 approx.) Gallons of Transmission Fluid (A59076)
LOT: (100 approx.)...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2004 DCT PUMP TRAILER (A58214)
2004 DCT PUMP...
2017 Ford F-350 Ext. Cab Pickup Truck (A56858)
2017 Ford F-350...
2011 GMC Yukon XL Denali (A56859)
2011 GMC Yukon XL...
