john deere 855 pto blows fuse when I sit on seat
   / john deere 855 pto blows fuse when I sit on seat #11
funny you mention the key as last year the tractor died in the middle of the road and I made a jumpset wire from the starter. so first I turn the key to the on position then touch the wires together to get the starter to engage. do you think cause that part of the ignition is messed that could be the case?
"Jumpset" (?) wire from the starter to where?
just the pto I could not get off the tractor without it shutting off. then after 1998 it would stay on when I got off the tractor. the tractor would stay running always like it should.
   / john deere 855 pto blows fuse when I sit on seat #13
With you off the seat and standing next to it, the tractor shouldn't start or stay running if things were normal.
Not so with 855. All the seat switch does is complete a circuit to an interlock that engages a magnet to engage the PTO. If you get off the seat, the PTO will disengage. The seat switch has nothing to do with the tractor starting or staying running.
From your description I'd say your problem is electrical in the seat switch circuit.
   / john deere 855 pto blows fuse when I sit on seat #14
Thanks for the update. It really help someone in the future doing a search to get a resolved answer.
2017 BX2680 Sub Compact Utility Tractor (A56436)
2017 BX2680 Sub...
WOODS 1033674 SUBFRAME KIT (A58376)
WOODS 1033674...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
2022 FORD F-250 (A58214)
2022 FORD F-250...
UNUSED AGT INDUSTRIAL PD680-PZ HYD DROP HAMMER (A58376)
UNUSED AGT...
PALLET OF MISC ELECTRICAL WALL BOXES & MISC CAPS (A58376)
PALLET OF MISC...
