John Deere 855 belly mower lift
   / John Deere 855 belly mower lift
Thanks. Before I replace draft arms and lift straps, I am going to try my ideas to swap or replace the struts that connect the rear of the deck to the mid-point lift arms. But this link will be useful identifying what I need. I've seen this before but was never sure it was the right one. I see blades, belts, spindles and anything else that might be needed. I just can't order anything from here. Any attempt requires me to specify a dealer and then states orders are no longer possible and redirects to shop.deere.com to start over, where the deck can't be identified. I might have better luck with each part number though. This should at least help identify the parts I am after.
   / John Deere 855 belly mower lift #22
I wasn't suggesting you replace anything, but figured these diagrams would help you identify and arrange the parts you already have, or possibly determine if anything is missing.
Yes, it's normal that you can't order off that version of the parts catalog, as I posted from the older/obsolete site. The new parts catalog site isn't nearly as good, so probably based on everyone hating their new site, they keep the old one online. It means that most end up using the old one to find the part numbers they need, then switch to the new one to order parts.
I think the old site just emailed the dealer, asking them to enter the parts order for you, into Deere's system. I think the new catalog was created to automate the process, now you are creating the order yourself, but the way you have to browse for parts was made much less convenient in the new system.
Old catalog:
Your tractor, in old catalog:
New catalog:
The new catalog is probably great if you want to order hats, t-shirts, and beer coozies. But I find it frustrating and nearly useless for actual tractor parts.
Also, when I reference a part number from the old site, the new site says it doesn't fit my 855 so am back to wondering if it is the right part after all. I just found a FB group specific to that series and they have a lot of recent posts so hoping to have some luck there. We'll see.
I do appreciate your help. It's certainly not something you need to do, so long after you've moved on from that situation but taking the time to share your experience and insight has been very helpful. I am slowly getting a feel for what I am up against and we all love a good challenge in our advanced years ;)
   / John Deere 855 belly mower lift #24
Hi. I have an 855 (love it) and also the 60" mid mower deck. The deck has been off and in a shed since I bought a green zero turn mower a few years ago. I also have the mower Operator's Manual you need. It has a part #OM-M91324 if you can find one. I don't have a scanner, so I took these pics of the pages for the wheels/leveling. I hope you can read them. Let me know if you need clarification. As I said, I don't use the mower any longer, but I can maybe help some...
Thank you. But it seems they only cover front-to-back levelling and not side-to-side, which I what I am after. Perhaps, that is simply because it is assumed you simply adjust the connector struts running from the back of the deck to the lift arms, which is my plan for today. We'll see but thanks again.
   / John Deere 855 belly mower lift #26
Page 14 has that covered. Sorry, I posted two dups and not this page. You loosen the lock nut and turn the yoke on the lift link. ;)
THANK YOU!!! That is exactly what my plan is. Except the links installed now cannot be adjusted (turned) because the previous owner welded them into a solid link. If swapping them side-to-side doesn't resolve the "lean", I can easily replace those links to make them adjustable again. Thanks again!!
Would you be interested in selling that manual? No biggie if not but I'd be willing...
   / John Deere 855 belly mower lift #28
Yeah, I also noticed the front supports (that adjust the front-to-back angles) were also welded, but not as big a deal since it is level enough for me and only using this mower for our 9 acre hay field. Like you, I purchased a zero-turn to handle the bulk of my everyday mowing that I care more about.
No worries about the manual. There's really not much to it - it's just a mowing deck (no rocket science needed) and I was on the correct path already for this problem. But correctly identifying the parts when needed is crucial so I'll likely pick one up eventually.
Thanks again!
Good afternoon. I hope your summer went well. I am now dealing with a radiator issue (finding one) but had to look up your previous reply about the hour meter functionality from last spring...
The reason being, I think mine IS actually recording the hours. The tach needle is still mostly missing but it now shows 845 hours and was 838 when I brought it home in March. It's been used very sparingly and never for very long, so with the calculations you cited above, 7 hours of use in the past 6 or 7 months seems quite possible so thanks for that.
Back to my radiator quest...
2018 WACKER NEUSON RTSC3 ROLLER (A54607)
2018 WACKER NEUSON...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2019 VOLVO L70H WHEEL LOADER (A52706)
2019 VOLVO L70H...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A54757)
UNUSED WOLVERINE...
2014 CATERPILLAR 299D SKID STEER (A52705)
2014 CATERPILLAR...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
