john deere 850 overhaul?
   / john deere 850 overhaul? #11
from the looks of that crank journal you are gonna need a new crank
   / john deere 850 overhaul? #13
So I dropped the oil pan and took a look around. looked like a small spoonful of metal in the bottom of the pan. The front main bearing was the one doing the knocking. Other main bearings had very little slop to them. Obviously the scoring on the connecting rod is an issue right? Other Connecting rods looked fine (to the human eye) It's impossible to know the condition of the crank without removing it completely right?? I know these photos don't help much but I did what I could. Any advice is very welcomed. how do I make my photos larger!?!?
Unfortunately That rod is damaged, it appears the bearing insert spun inside of the rod end - which didn't just damage the crank journal.
It (may) be possible to have it re sized but if they have to remove much material the pistons installed height will be lower and affect that cylinders compression ratio also it would be hard to trust the rod bearing inserts to be properly retained .
Probably better to also source a new rod and check its weight/ balance to the existing undamaged rods.
Hope this is helpful and good Luck,
2012 BROCE BROOM (A50854)
2012 BROCE BROOM...
Unused 2025 CFG MH12RX Mini Excavator (A49461)
Unused 2025 CFG...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2008 INTERNATIONAL DURASTAR 4300 SERVICE TRUCK (A50854)
2008 INTERNATIONAL...
2019 BOBCAT S770 SKID STEER (A51242)
2019 BOBCAT S770...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2018 FREIGHTLINER...
