john deere 820 shifting problems
/ john deere 820 shifting problems #1
banditman
john deere
the other day raking with a john deere 820 the right shifter wouldnt shift into park or II so i pulled the top of the trans off and found a 2 inch long by maybe 1/4 inch diameter tube laying in the shift fork which was keeping the shift lever from being able to shift. Does any body have any idea what that could be?? The trans shifts fine now but that piece of tube came from somewhere.
/ john deere 820 shifting problems #2
That the JD model 820 2-cyl diesel?
/ john deere 820 shifting problems #3
820 with 2 cyl only park function was locking both turning brakes. It would be interesting to see photo of tube Banditman removed from shifter rail tab.
/ john deere 820 shifting problems #4
The 3 cylinder 820, 1968-73 model we can presume?
Most likely part of a transmission lube line.
/ john deere 820 shifting problems #5
Will need to hear back from banditman to know for sure.
TT may have it pegged correctly.
The three point arms on this tractor have never worked right. They kind of bounce and shake when you raise them could this be the cause?
/ john deere 820 shifting problems #8
Probably not related. That sounds more like the lift cylinder has a leak/bad oring or the pump has a bad piston/valve. Does the 3pt stay in the up position after the tractor has been shut off?
/ john deere 820 shifting problems #9
Poor trans shifting & hyd's on a '73 JD 820 have no affect on each other. How many hrs of use since hyd filter was changed & hyd oil suction screen che3cked/cleaned?
/ john deere 820 shifting problems #10
The screenshot doesn't mention cleaning the suction screen. That's normally done every other oil change.
/ john deere 820 shifting problems #11
I tend to disagree on that. I think it's more often done when hydraulic problems occur and nothing else seems to help.
i did it before i started haying probably 20 hrs on the filter and cleaned screen
/ john deere 820 shifting problems #13
And I disagree. If we wait for symptoms before cleaning screens, the cavitation damage to the hydraulic pump rotor has already started. It's called micro-pitting and will wear the rotor out prematurely.
The jerking and jumping of the 3pt hitch are classic signs of suction oil starvation. First thing to do is check the oil, change the spin on filter, and clean the screen. 3pts operation is normally very smooth.
The pipe on top of the shifter sounds like a separate problem.
rScotty
/ john deere 820 shifting problems #14
Good, But was it still shifting then? Something changed in the transmission when it stopped shifting. That pipe came from somewhere.... and that means particles. Maybe enough to clog the filters and maybe not...
/ john deere 820 shifting problems #15
I was wondering if original poster could get a picture of the pipe found in shifter. Might help to identify it. If there is internal leakage due to misplaced or broken pipe, it would help explain the jerky hitch.
yes i will see if i can get one
sorry for late reply anybody know why I'm not getting emails that I have received answers?
/ john deere 820 shifting problems #20
??? Don't understand the question. please elaborate.
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
WOODS 3120 BATWING MOWER (A60430)
WOODS 3120 BATWING...
2018 Isuzu FTR Landscape Dump Truck (A61573)
2018 Isuzu FTR...
2025 Hydraulic IRANCH Tilt Bucket Mini Excavator Attachment (A61572)
2025 Hydraulic...
2004 Rogers Detach Lowboy, 28' Well, Tandem Axel (A62679)
2004 Rogers Detach...
POLY WRAP CORES (A63291)
POLY WRAP CORES...
