John Deere 820 Hydraulic Fluid Pressure & GPM specs?
   / John Deere 820 Hydraulic Fluid Pressure & GPM specs? #1
Rainboy
Romney WV
john deere 820
We're looking at installing a 3 point hitch-mounted (BOSS) Log Splitter on our John Deere 820. The specs show it runs about 2100 psi, but I can't find the GPM flow rate.
?Can anyone provide the GPM flow on this tractor? AND Is this a good idea to use the tractor 3 point to spit logs. Boss says it should be 8?5 GPM at 1500-2000 PSI?
Thanks in advance.
   / John Deere 820 Hydraulic Fluid Pressure & GPM specs? #2
I've never used a three point log splitter, but the hydraulics on your tractor will be more than enough
   / John Deere 820 Hydraulic Fluid Pressure & GPM specs? #3
While they do work, 3 point log splitters are painfully slow most of the time when run off of the tractors hydraulic system. I have seen a few that use a PTO driven pump and those seem to work better.
   / John Deere 820 Hydraulic Fluid Pressure & GPM specs? #4
I think the open-center hyd's on a 820 with 3cyl engine will operate a log spitter very slowly.
   / John Deere 820 Hydraulic Fluid Pressure & GPM specs? #5
Tx Jim did you get a email from me? Lee
As said the tractor hyd flow would be way to slow.
   / John Deere 820 Hydraulic Fluid Pressure & GPM specs? #6
Tx Jim did you get a email from me? Lee.
Lee
I just sent you a reply. IMHO TBN leaves a little to be desired on PM notifications as I was unaware that you had PM'd me.
Jim
   / John Deere 820 Hydraulic Fluid Pressure & GPM specs? #7
An 820 3 cylinder at rated speed will make a full stroke cycle in about 30 seconds using a 5x24 cylinder. Pretty slow imo.
CAT D4D (A45046)
CAT D4D (A45046)
2014 GOOSENECK DRIVER SIMULATOR TRAILER (A45046)
2014 GOOSENECK...
Miller Welder (A44502)
Chery 20' Bi-Parting Iron Gate (A44502)
Chery 20'...
PT PTO Driven Canal Pump (A44501)
PT PTO Driven...
2015 Ford F-250 Pickup Truck (A44572)
2015 Ford F-250...
