John Deere 820 Hydraulic Fluid Pressure & GPM specs?
   / John Deere 820 Hydraulic Fluid Pressure & GPM specs? #1
Rainboy
Romney WV
john deere 820
We're looking at installing a 3 point hitch-mounted (BOSS) Log Splitter on our John Deere 820. The specs show it runs about 2100 psi, but I can't find the GPM flow rate.
?Can anyone provide the GPM flow on this tractor? AND Is this a good idea to use the tractor 3 point to spit logs. Boss says it should be 8?5 GPM at 1500-2000 PSI?
Thanks in advance.
   / John Deere 820 Hydraulic Fluid Pressure & GPM specs? #2
I've never used a three point log splitter, but the hydraulics on your tractor will be more than enough
   / John Deere 820 Hydraulic Fluid Pressure & GPM specs? #3
While they do work, 3 point log splitters are painfully slow most of the time when run off of the tractors hydraulic system. I have seen a few that use a PTO driven pump and those seem to work better.
   / John Deere 820 Hydraulic Fluid Pressure & GPM specs? #4
I think the open-center hyd's on a 820 with 3cyl engine will operate a log spitter very slowly.
   / John Deere 820 Hydraulic Fluid Pressure & GPM specs? #5
Tx Jim did you get a email from me? Lee
As said the tractor hyd flow would be way to slow.
   / John Deere 820 Hydraulic Fluid Pressure & GPM specs? #6
Tx Jim did you get a email from me? Lee.
Lee
I just sent you a reply. IMHO TBN leaves a little to be desired on PM notifications as I was unaware that you had PM'd me.
Jim
   / John Deere 820 Hydraulic Fluid Pressure & GPM specs? #7
An 820 3 cylinder at rated speed will make a full stroke cycle in about 30 seconds using a 5x24 cylinder. Pretty slow imo.
16in Excavator Bucket (A44391)
16in Excavator...
2016 Ford Escape SUV (A44572)
2016 Ford Escape...
PALLET OF PIPE FUSION EQUIPMENT (A45333)
PALLET OF PIPE...
Alitech Planing Head Attachment (A42021)
Alitech Planing...
2014 FREIGHTLINER M2 TANDEM AXLE FLATBED WITH MOFFETT HOOK UP (A43004)
2014 FREIGHTLINER...
2011 Ford Ranger 4x4 Pickup Truck, VIN # 1FTLR4FE5BPA48505 (A44391)
2011 Ford Ranger...
