John Deere 790 HELP! sounds like grinning gears when moving
   / John Deere 790 HELP! sounds like grinning gears when moving #1
CountryGirlCityGirl
middleport, ny
john deere 790
Hello, when i started up my joh deere 790, no problem until started to move and it sounds like its grinding the gears when its in 1st, 2nd and going backwards. Stalls out at 4 & 3rd gear, any ideal what the problem is? the PTO fluid is low could that be it? oil level is good. Coolant is low
   / John Deere 790 HELP! sounds like grinning gears when moving #2
When you press the clutch in, does it act like the brakes are being applied? Does it stop immediately after you clutch?
Yes it only stalls out in higher gears
   / John Deere 790 HELP! sounds like grinning gears when moving #4
Make sure the parking brake isn't applied. If it is not applied check your brake linkages.
   / John Deere 790 HELP! sounds like grinning gears when moving #5
The "PTO fluid" is also the same fluid for the transmission and the hydraulics. If it's low, top it off and see if that makes a difference.
   / John Deere 790 HELP! sounds like grinning gears when moving #6
you have transmission problems, have it checked before it locks up
   / John Deere 790 HELP! sounds like grinning gears when moving #7
Any obvious fluid leaks? I've let my transmission/hydraulic fluid get a little low in the past but the gear noise is just louder. Not grinding or stalling. So I'd agree with whis above. Sounds bad.
   / John Deere 790 HELP! sounds like grinning gears when moving #8
My money is on parking brake. Either left on or linkages bound. OP, do you know what to look for?
   / John Deere 790 HELP! sounds like grinning gears when moving #9
I've left my brake on plenty of times. It never made a grinding sound and could not stall the tractor even in 4th gear. Now, my brakes are wet. Not sure about the JD 790.
   / John Deere 790 HELP! sounds like grinning gears when moving #10
Dry on 790. I've left it on and it definitely makes an odd noise.
2019 Ford F-150 XLT Sport Pickup Truck, VIN: 1FTEW1EP3KFA58619, Crew Cab, 4 x 4, 2.7 L EcoBoost Gas (A59076)
2019 Ford F-150...
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
EPPS Powerhouse Pressure Washer (A55973)
EPPS Powerhouse...
2018 Ford F-350 Flatbed Truck (A55973)
2018 Ford F-350...
LOT: (40) 14 Oz. Tubes of Red Lithium Complex NLGI #2 Grease (A59076)
LOT: (40) 14 Oz...
3" X 3" WP-80 WATER PUMP (A52708)
3" X 3" WP-80...
