John Deere 770 no power
   / John Deere 770 no power #1
Loop64
Springville, ny
John Deere 770
I went to start my 770 yesterday and I heated the glow plugs by turning the ignition counter clockwise for 10 seconds ( as normal) then went to start it and it turned over for a second then I lost all power ( no lights. No red lights on the dash) I checked everything as much as I can... Power to the starter and power to ignition switch (12.6 v). Any ideas.. Thanks in advance
Dave
   / John Deere 770 no power #2
Dave
So, the solenoid is throwing power to the starter? Ken Sweet
   / John Deere 770 no power #3
If your loosing power to gauges and to the starter but getting a voltage reading look for a loose ground wire. There may be several. One on the frame in the engine area, one could be under the dash and one on the engine block..
I found a ground issue on the frame. Thank you very much for the help. I can catch up on the snow plowing now!
A & B 5' 3pt Blade (A50121)
A & B 5' 3pt Blade...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
