John Deere 755 engine stopping
   / John Deere 755 engine stopping #1
robbridgland
Bucknell UK
John Deere 755
Hi
My John Deere 755 suddenly the engine started to stop
Would restart for 5 seconds then stop again
Looked and saw solenoid to fuel shut off was closing
If I hold it open engine runs fine
Any idea of causes. Ignition switch isn't brilliant so I am going to get replacement
I am an Engineer and have multi meter and was going to check seat switch
Any other pointers gratefully recieved
Otherwise great little tractor bought used. if it ever goes badly wrong I am going to have to buy new or have wife leave me
   / John Deere 755 engine stopping #2
Check for voltage to the solenoid after it stops. Probably a bad coil on the solenoid, or at least thats what it sounds like.
   / John Deere 755 engine stopping #3
Check the power supply to the solenoid coil. There may be a loose wire, etc thats going "open circuit" once the engine starts that allowing the solenoid to close the fuel suppply.
   / John Deere 755 engine stopping #4
The fuel stop solenoid on my 5300 failed during a day I was discing food plots for a friend. Had to open it up and take the plunger assembly out. Ran fine but had to stop the engine by stalling it with brake and clutch. Seemed it was a weak design.
Went to solenoid found loose wire on connection problem solved . You saved me hours many thanks
Very much appreciated
Rob
2018 INTERNATIONAL LT625 (A52472)
2018 INTERNATIONAL...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2008 CATERPILLAR 320D L (A52472)
2008 CATERPILLAR...
2011 Mack CHU613 T/A Wet Kit Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
2007 KENWORTH W900L DAY CAB (A52472)
2007 KENWORTH...
