John Deere 750 rockshaft
/ John Deere 750 rockshaft #1
Native Texan
John Deere 750
I have a Deere 750 that sat for several years unused. The arms are not lifted when pulling back on the lift handle. I just downloaded the Deere manual but am not sure what different valves might cause this problem. What different items should I check?
/ John Deere 750 rockshaft #2
Welcome to the forum!
First off , have you checked the basics? Condition and level of hydraulic fluid? Replaced filters and cleaned the hydraulic screen if it has one? Does the power steering work?
We need to know what has been done already in order to further the process of diagnosing.
There is no power steering. I have loosened the banjo fitting from at the rockshaft and there is lot of fluid pressure. I don't know how to attach a pressure gauge to check the exact pressure. The stop valve threaded shaft is broken but I believe it hasn't been moved since it worked in the past. There is zero movement of the piston. My guess is there is some valve open in the rockshaft piston cover that should be closed. I pulled the rockshaft control valve off and the piston that is moved by the rockshaft control quadrant moves freely but I didn't know how to check anything else in that system. My first guess is that I need to check out the piston in the other end of the rockshaft control to see if it is stuck open.
/ John Deere 750 rockshaft #4
What I would do is pull the bleed off valve that controls the fluid movement to the rockshaft piston first. I bet it's either seized up or clogged up.
I just pulled the endcaps (cannot find the page that describes them with the correct terms) off of the rockshaft control. I found that the piston (maybe that is the right term) is stuck. It does not move. I ran out of time but plan to work on it the next dry day here in Fort Worth. Any suggestions about how to free it up?
Unused 2024 Ray Tree RMSC78 Soil Conditioner Skid Steer Attachment (A59228)
Unused 2024 Ray...
FRESHLY REFURBISHED! 2016 KBH Fertilizer Tender Trailer - Isuzu Diesel (A61307)
FRESHLY...
20 LOWBOY BUMPER PULL TRAILER (A55745)
20 LOWBOY BUMPER...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2016 Freightliner M2 106 Altec AM50 50ft. Bucket Truck (A59230)
2016 Freightliner...
2017 Toyota Camry Hybrid Sedan (A59231)
2017 Toyota Camry...
