John Deere 750-loader bucket works but lift will not
   / John Deere 750-loader bucket works but lift will not #1
Dick D
Stone Mountain, Ga
John Deere
I installed a new pump,and all was well. Both bucket and lift worked at first then when I tried to use my box scrape it lowered and will not lift, the loader bucket will work.
   / John Deere 750-loader bucket works but lift will not #2
If you go to Deere parts and look up your model. You should be able to find a break down of your tractor. It is very possible you have air some where in your system. Hopefully looking at different breaks downs of your tractor you can see where the oil flows up to the rockshaft and related valve.
   / John Deere 750-loader bucket works but lift will not #3
Did all hyd plumbing remain the same when pump was exchanged IE all hoses are attached as originally? Have you looked to be sure 3 pt control linkage is attached correctly?
2017 Mack CHU613 Day Cab Truck Tractor (A53117)
2017 Mack CHU613...
2025 CFG Industrial STSD10 (A50123)
2025 CFG...
Doosan DX85R (A50123)
2018 Bobcat T590 (A50123)
2018 Bobcat T590...
377811 (A48836)
377811 (A48836)
2025 K1220 UNUSED Single Garage Metal Shed (A53117)
2025 K1220 UNUSED...
