Planters John Deere 71 Flex Planter
/ John Deere 71 Flex Planter #1
jbcare
Broxton Ga
Model A. JD 71 Flex,
I have a JD 71 Flex planter and a box of plates. I am not sure what plate to use for what seeds. Can anyone help me with where I might find a chart online that shows which of the B plates plant what seeds? Any help would be appreciated.
/ John Deere 71 Flex Planter #2
That planter uses the same plates as the older model 246 which I use. It sounds like you are worrying a little too much about how to select the proper plates. I use a set of medium round corn plates for any corn seed that I have had. My 246 has 3 positions for the drive chain which will drop seeds at 3 different spacings (4", 8", 12" or so). Some sweetcorn varieties (kandy corn for example) have very small seeds, and 2 seeds will drop in each opening of the medium round plate, so I will set the drive chain to the furthest setting. Others, like silver queen, are large flat seeds and will sometimes miss so I will set it to lay down the most seed. Any fieldcorn I have used has worked well with the medium round plates, so I usually set it on the middle setting with that. My recommendation would be to compare your seed to you selection of plates, and choose those that match best, maybe erring a little on the big side. Then place some seed in the hoppers and pull it across the grass, checking out the spacing. Those planters can also be used for beans, peas, and pumpkins. It is a simple task, with a dremel tool and some JB weld, to modify any set of plates to give you any spacing you want. Pumpkins will often be planted with just 1 or 2 seeds per revolution. Those plates are litterally a dime a dozen and many folks have bushels of them laying around their barns. You dont have much to loose by hacking some up with a grinder and/or laying in a little epoxy.
Thank you. This is very helpful information. I will try this. But I would also like to have a reference chart or list that would sometimes make the process of selecting the correct plate with out the hassel of trial and error. The plates that I have have the number B0-24 through B190-24 on them. It would be convenient to be able to find something that says plate B0-24 plants this and this and this. Do you know anywhere that something like this could be found. or is there a thread where every one post what seed they know for a fact works with what plates. This would be useful information to everyone, especially me who has only some experience.
/ John Deere 71 Flex Planter #4
Go to Lincoln Ag Products. This should give you all the information you need regarding plates.
