John Deere 6x4 Gator Stack Exhaust
   / John Deere 6x4 Gator Stack Exhaust #11
One more addition if u don't mind...
Clappers on the stacks!
Will increase the LCF and stop unwanted moisture/rain from entering if parked outside
77bronco said:
Are you going to put some kind of heat shield on the stacks to prevent getting burned when getting in and out?
Does not get hot enough to worry about. However, I would like to find some material like my Denali grill to bend and mount over them. I think it would look pretty cool. Honeycomb type material.
hotiron01 said:
I CANNOT let my 12 yr old see this. Otherwise my Ranger would have stacks!! :cool::cool:
Hope does not see it then. Building the manifolds was a bear.
Got the clappers. It sits in a heated barn, not outside. Not sure why the condensation is so much.
   / John Deere 6x4 Gator Stack Exhaust #15
Make sure to post a video with clappers
You may want to use high heat primer and paint on those to keep them rust free
Don't have a video but a picture from heading up hunting this year.
Will look into paint or possibly powdercoat or chrome.
   / John Deere 6x4 Gator Stack Exhaust #17
cool!
Because the pipes don't get hot, the moisture from the combustion never evaporates.
consider drilling a small hole and turning a small sheet metal screw in.......it will weep a small amount and not sound like a leak...
Deadman said:
cool!
Thanks for the tip!
2013 International WorkStar 7400 Altec AM547 50ft. Bucket Truck (A56858)
2013 International...
Bucket Pallet Forks (A57454)
Bucket Pallet...
2003 INTERNATIONAL 9900I (INOPERABLE) (A58214)
2003 INTERNATIONAL...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58216)
HYDRAULIC THUMB...
2023 CAT 249D3 Compact Skid Steer (A59213)
2023 CAT 249D3...
SDLanch 12'x20' High-End Carport (A57149)
SDLanch 12'x20'...
