john deere 670 with 60 loader
   / john deere 670 with 60 loader #1
malichi
lagrange
john deere 670
need to replace hydraulic hoses and repair leaking hydraulic cylinders
   / john deere 670 with 60 loader #2
Quite a job, are you planning on rebuilding the cylinders yourself?
   / john deere 670 with 60 loader #3
Were you asking a question on how to do this?
   / john deere 670 with 60 loader #4
If you meant to add a question mark to your post you can find parts and prices at Deere's web site. John Deere - Parts Catalog
You can get hoses made many auto parts shops. Sometimes for less than JD prices, Sometimes there are local hydraulic repair shops that may sell you seals. The JD website has seal kits. Of course your rods need to be in good shape or they will tear up seals.
I see La Grange is in Georgia, Texas, Ohio, Illinois, Missouri, Indiana, New York, Kentucky, Tennessee, and probably some other states. Kind of a huge area to be from. :welcome: I figure you must be from Georgia since that is where I live. But maybe you are from Ohio because I lived there before.
Thanks for the reply and I live in Georgia. If I can secure the parts and a diagram I will attempt a rebuild on the cylinders.
   / john deere 670 with 60 loader #7
The JD part catalog should help.
To JimRB, I have the cylinders off, both cleaned up on outside, one cylinder seperated from tube. The lock ring was a bother but got it anyway. The other cylinder is still assembled due to stubborn lock ring. Can't get the sucker to rotate or move period. Its just stuck, put on wd40 last evening. Wanted to get both cylinders dissambled before reassembling. Rods on both appear in good shape. Just an update, appreciate your interest and any advice welcome. I do have cast iron component on rod. Thanks, malichi
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
2017 Ford F-350 Ext. Cab Pickup Truck (A49461)
2017 Ford F-350...
Toro Z Master Mower (A50324)
Toro Z Master...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2016 Ford F-450...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
TOOLBOX/FUEL TANK COMBO (A50854)
TOOLBOX/FUEL TANK...
