John Deere 670 W/60 Loader
   / John Deere 670 W/60 Loader #1
TPR37777
SEATTLE, WA
JOHN DEERE 870
I hate to be a mooch for information but I just bought a John Deere 670 with 60 loader on it and three of the loader pins will not accept grease at the fitting (I believe it sat for some time). I have to pound out the pins to clear everything out but they are really bound up in there something fierce. Before I apply heat to the pins, does anyone know if there are any o-rings or anything else in there that the heat would destroy? Is there any other trick I am missing to free up the pins or is brute force the only avenue?
   / John Deere 670 W/60 Loader #2
Dumb question, can't you replace the grease fittings? Are these the loader-tractor mounting pins or the bucket-loader mounting pins?
Take a look at the exploded diagram on the Deere parts website to see what else might be in there for hardware.
   / John Deere 670 W/60 Loader #3
The 70 does not have o-rings, so I would expect that the 60 does not either.
   / John Deere 670 W/60 Loader #4
Went through this recently with a 7 backhoe. I had to remove the grease zerks, carefully clean the hardened grease out of them with a small drill bit by hand. Then beat the pins out of their bores with a brass drift and clean all the hardened grease from the pins and the bores with a scotchbrite pad. I also had to clean the hardened grease plug out of the grease channel between the bottom of the zerk and the bore. Then reassmeble and grease away. I couldn't get several of the zerks to take grease and had to replace them. I also discovered that one of the pins was badly worn due to the PO's lack of greasing. That pin had to be replaced.
1997 INTERNATIONAL 8100 4X2 WATER TRUCK (A50458)
1997 INTERNATIONAL...
2008 CATERPILLAR 314CL CR EXCAVATOR (A51242)
2008 CATERPILLAR...
2014 Kia Cadenza Sedan (A50324)
2014 Kia Cadenza...
2019 FORD F550 XL SERVICE TRUCK (A51243)
2019 FORD F550 XL...
Non running toro mower (A48082)
Non running toro...
Case Ih 2388 Combine (A50514)
Case Ih 2388...
